Hi I was having trouble trying to install Laser Beat plugin as it is for 32 bit Virtual Dj. Can you please tell me if Laser plugin works on 64 bit virtual Dj 2023 with Pangolin Quickshow 5.2 by syncing the lasers with the beat of the music?
Thanks
Thanks
geposted Mon 29 May 23 @ 3:20 pm
Hello, I have the same problem...
I can't reinstall laser beat since vjd 2023 and quickshow 5.2.
Is anyone found something ?
Thanks
Thanks
geposted Sun 17 Sep 23 @ 6:48 pm
