so this is my make a mix on vacation laptop. now using windows 11. it stut stut stuters. even with stems disabled. the waveforms can hardly draw. it does have some intel gpu also in the machine.
should i re install windows? or put win 10 back on? i usually just use a denon mc6000mk2 for this one.
it had 12 cores. 6 real ones. i would think this lappy is powerful enough to work with vdj. even with reduced quality stems?
or should i download an older version of vdj?
geposted Tue 30 May 23 @ 7:15 am
its
CPU Specifications
Total Cores
6
Total Threads
12
Max Turbo Frequency
4.90 GHz
Processor Base Frequency
1.10 GHz
Cache
12 MB Intel® Smart Cache
Bus Speed
4 GT/s
TDP
15 W
Configurable TDP-up Base Frequency
1.60 GHz
Configurable TDP-up
25 W
Configurable TDP-down Base Frequency
800 MHz
12.5 W
CPU Specifications
Total Cores
6
Total Threads
12
Max Turbo Frequency
4.90 GHz
1.10 GHz
Cache
Bus Speed
4 GT/s
TDP
15 W
1.60 GHz
Configurable TDP-up
25 W
800 MHz
12.5 W
geposted Tue 30 May 23 @ 7:18 am
