Topic: 2 controllers 2 licenses?
Hi folks,
I am enjoying using Virtual DJ. I am currently a monthly subscriber as I wanted to test it with my controllers. I am using the Traktor X1 and Z1.
Would I need to buy 2 licenses one for each controller or would one work for both?
I don't play professionally and it's just for fun.
geposted Tue 30 May 23 @ 2:40 pm
As a Pro subscriber ... you can use any controller.
(VDJ will work with all controllers)
geposted Tue 30 May 23 @ 2:49 pm
Thanks for the reply. I wasn't clear in my initial question. I want to come off the monthly subscription in favour of a controller license.
The question I have is, do I need to buy license for both my controllers?
geposted Fri 02 Jun 23 @ 9:55 am
Yes the controller licenses are controller specific.
So if you have 2 different controllers you would need 2 different licenses.
It may be worth looking into the Pro Infinity license. This is a one off cost and covers all controllers and future updates and controllers.
geposted Fri 02 Jun 23 @ 10:27 am
SepatroPRO InfinityMember since 2019
I would also recommend that...
geposted Fri 02 Jun 23 @ 4:11 pm
Thanks for the replies. I think in this very specific case it might make sense for my to try Traktor first before committing to either platform.
Either way I have really enjoyed using VDJ so I might end up back here soon.
Thanks again.
geposted Tue 06 Jun 23 @ 12:33 pm
