From the description in the handbook it seems that both, Smart Loop and Quantize, do the same job: aligning manually set loop points with the CBG.
So, what's the exact difference between these two options? When should I prefer one over the other?
Your answer is appreciated.
geposted Sun 04 Jun 23 @ 3:41 pm
smart_loop is for the length of the loop.
example: you push loop_in wait 4 beats and push loop_out. The set Loop is correct 4 beats long.
quantize_loop set the start of the loop on the grid (globalQuantize).
example: setting globalQuantize is 1 beat. The Loop is placed directly on the grid.
geposted Mon 05 Jun 23 @ 4:41 am
Thank you so much for this excellent, very helpful piece of information!
geposted Mon 05 Jun 23 @ 7:52 am
So that's what those grey markers are for, now I know
geposted Mon 05 Jun 23 @ 8:22 am
