Hello everyone, I am trying to create a custom mapping for my Hercules DJ Console MK2 and need some help... On the left deck, the physical buttons are FX3, FX2, FX1. But on the right deck, the corresponding physical buttons are FX1, FX2, FX3...
So at the moment, my code on the FX1 button is:
var 'djc' 0 ? deck left effect select +1 & deck right effect select -1 : var 'djc' 1 ? hot_cue 1 : loop_double
I need help with this part: "deck left effect select +1 & deck right effect select -1"
this 'works' but it is lazy programming.
What I'd like is for the system to know when I am pressing the FX button on the left side versus the right side. Is there any way to detect this? I was trying to do some kind of IF statement using deck_select but couldn't figure it out, any tips please?
geposted Mon 05 Jun 23 @ 8:48 am
Strange that the Keys are named like that. Is yoru device labeled like this , or is it how the Keys come up when pressed ?
The query is device_side 'left' ? ActioForLeftSide : ActionForRightSide
So try ..
FX1
FX3:
So try ..
FX1
var 'djc' 0 ? device_side 'left' ? effect_select -1 : effect_select +1 : var 'djc' 1 ? device_side 'left' ? hot_cue 1 : hot_cue 3 : device_side 'left' ? loop_half : loop_double
FX3:
var 'djc' 0 ? device_side 'left' ? effect_select +1 : effect_select -1 : var 'djc' 1 ? device_side 'left' ? hot_cue 3 : hot_cue 1 : device_side 'left' ? loop_double : loop_half
geposted Mon 05 Jun 23 @ 2:28 pm
@DJDAD thank you so much for your help, spot on!!
For anybody else with a Hercules MK2, here is the final custom mapping:
FX1 BUTTON:
FX2 BUTTON:
FX3 BUTTON:
PITCHBEND+ BUTTON:
PITCHBEND- BUTTON:
FX1 BUTTON:
var 'djc' 0 ? device_side 'left' ? effect_select -1 : effect_select +1 : var 'djc' 1 ? device_side 'left' ? hot_cue 3 : hot_cue 1 : device_side 'left' ? loop_double : loop_half
FX2 BUTTON:
var 'djc' 0 ? effect active : var 'djc' 1 ? hot_cue 2 : loop_button
FX3 BUTTON:
var 'djc' 0 ? device_side 'left' ? effect_select +1 : effect_select -1 : var 'djc' 1 ? device_side 'left' ? hot_cue 1 : hot_cue 3 : device_side 'left' ? loop_half : loop_double
PITCHBEND+ BUTTON:
loop_move +1
PITCHBEND- BUTTON:
loop_move -1
geposted Mon 05 Jun 23 @ 8:40 pm
DJRogerBorges wrote :
For anybody else with a Hercules MK2, ...
Yeah there must be plenty LOL
geposted Tue 06 Jun 23 @ 12:18 am
