Topic: [M-AUDIO OXYGEN] MAPPING
Hello, i can't mapp the oxygen m-audio because when i mapp the pad and the slicers on the power on of the fx and on the dry/wet of the left fx, then i mapp the one on the right, at the end by pushing a pad of the right or moving a slicer to the right, a parameter of the left side always moves and so on.
geposted Tue 06 Jun 23 @ 1:55 pm
This is how I've done it for an M-Audio Oxygen25 midi keyboard
There's a link to the actual mapping in the video description:
geposted Tue 06 Jun 23 @ 2:21 pm
Thanks for the support but, there's the same problem with right and left side of the mapping, when I map the left side then one botton and slider moves the other side parameters..Why? How might I use the reader section? Or is another problem?
geposted Wed 07 Jun 23 @ 6:10 am
