Hi,
Can anyone explain this or is it a bug...?
I have an Instant Filter set up to List Year in Range 10.
It works fine up to 2009 then it can no longer count in 10s. The next entry in the list is 2010-2014, then 2015-2019, 2020-2020.
I have changed the range to be 5 and also 20 and the range works perfectly. It only seems to be range 10 that give me weird results.x
Can anbody help?
Many thanks.
Howard
Using VDJ for Mac build 7582.1971
Can anbody help?
Many thanks.
Howard
geposted Fri 09 Jun 23 @ 3:20 pm
It is by design that the more recent years are split up further
geposted Fri 09 Jun 23 @ 7:20 pm
OK. Thanks for the info. Much appreciated.
geposted Fri 09 Jun 23 @ 7:50 pm
