Topic: GeForce GTX1650 & Stems 2.0
jatoroHome userMember since 2006
Hi good morning.
I'm testing the latest VDJ beta with stems separation 2.0.
I have a Lenovo Legion 5 15arh05 laptop with the following specifications:
AMD Ryzen 7 4800H/16GB/1TB SSD/GTX 1650.
I can't get a separation of stems 2.0 in real time. It takes sometimes between 5 o 6 seconds, and sometimes i don´t notice nothing.
I would like to know if the specifications of my laptop are enough or, if so, what should I optimize?
I also can't locate the saved stems separately. I have automatic stem saving enabled.
I await your response. Thank you. A cordial greeting.
geposted Sat 10 Jun 23 @ 11:36 am
