MacBook Pro running Ventura 13.4. I opened up the application to do some music filing, window popped up said VDJPro had been updated and do I want to use it. I clicked "yes" and now it won't open. Says "the application virtualDJ can't be opened", what happened? What is the resolve? TIA
geposted Sun 11 Jun 23 @ 9:59 pm
Manually installing either the current stable from https://www.virtualdj.com/download/index.html or the current Early Access build from https://www.virtualdj.com/download/build.html should work fine though
geposted Mon 10 Jul 23 @ 4:29 am[ selected best answer by Adion on Wed 12 Jul 23 @ 2:16 am ]
Same here. I've just opened a ticket with VDJ for the same reason.
geposted Mon 12 Jun 23 @ 10:16 pm
Download the full installer from https://www.virtualdj.com/download/index.html
geposted Mon 12 Jun 23 @ 10:25 pm
This issue seems appears for multiple persons, I posted my experience in this already opened post : https://www.virtualdj.com/forums/247463/VirtualDJ_Technical_Support/virtual_dj_8_won_t_open_after_update.html
Reinstalling vdj will working but if you accept to update it when requested, it will be broken again...
geposted Tue 13 Jun 23 @ 1:46 pm
well I made a backup copy, uninstalled, reinstalled and went to "restore" my backup file but it's not wanting to pull it... when I click on the actual file it opens to all the folders inside it and wants me to choose one of those...what am I doing wrong so that it brings in the entire "VirtualDJ" folder in the restore?
geposted Thu 15 Jun 23 @ 10:28 pm
What version of vdj are you all using?
geposted Thu 15 Jun 23 @ 10:53 pm
Got this issue too. Running on a Macbook Pro M1 8Gb on OS Ventura 13.4.1. Just had to turn off updates for now. For the past 2/3 weeks getting this problem. Just have to use version : virtualdj_2023_b7555_mac. Hope This helps.
geposted Sun 09 Jul 23 @ 8:21 pm
Just FYI working fine here;
My System Specs;
M1 MacBook Pro (14-inch, 2022), Apple Silicon M1 Pro, 16gb, 500 gb SSD, macOS Ventura 13.4.1, VirtualDJ Early Access v2023-m b7600.
My System Specs;
geposted Sun 09 Jul 23 @ 10:19 pm
It appears on some macs the update process indeed fails.
Selected as best answer geposted Mon 10 Jul 23 @ 4:29 am
I just update VDJ and it won't open up. Using MacBook Pro Ventura 13.4.1
geposted Wed 12 Jul 23 @ 1:55 am
This is very terrible. Same just happed to me. Im preparing for a gig tomorrow and the update came up. As soon as i updated i get "The application “VirtualDJ” can’t be opened." doesn't feel like this was tested through & though before rolling out
geposted Wed 12 Jul 23 @ 11:29 pm
@adion from your answer I assume you were able to reproduce this bug.
When will it be fixed?
I didn‘ t have this bug at the beginning and suddenly (after over a year on the same machine) it appeared out of nowhere …
geposted Sat 15 Jul 23 @ 7:39 pm
Unfortunately it seems to be something Apple changed that prevents the update from being applied correctly.
It is fixed in build 7600 but we can't fix the updater in older versions unfortunately.
geposted Sun 16 Jul 23 @ 8:34 am
