Topic: Custom Pad Page: 4 Decks on 2 Deck Controller
Buttons:
- Select Left/ Right Deck
- Pitch Reset
- Line Rec
- Pitch Lock
- Open Recording Settings
- Browser Zoom
- BPM half or double
- Beat Lock
- In/out or Loop recording to Sample Bank
- Prelisten (while pressed)
Create an xml-file with the following code and save it here \Documents\VirtualDJ\Pads
In the pad-page-menu assign the name of your xml-file to the button you want.
<?xml version="1.0" encoding="UTF-8"?>
<page name="custom">
<pad2 name="Pitch Lock">pitch_lock</pad2>
<pad3 name="Line Rec">linein_rec</pad3>
<pad1 name="Pitch Reset 1%">pitch_reset 1%</pad1>
<shift_pad7 name="Master Record">record_config</shift_pad7>
<shift_pad3 />
<shift_pad2 name="B">deck 2 rightdeck</shift_pad2>
<shift_pad1 name="A">deck 1 leftdeck</shift_pad1>
<shift_pad5 name="C">deck 3 leftdeck</shift_pad5>
<param1 />
<param2 />
<shift_pad6 name="D">deck 4 rightdeck</shift_pad6>
<shift_pad8 name="Browser Zoom">browser_zoom</shift_pad8>
<shift_pad4 name="BPM /2">set_bpm 50%</shift_pad4>
<pad6 name="Beat Lock">beatlock</pad6>
<pad7 name="Deck Record">sampler_rec</pad7>
<pad8 name="Prelisten">prelisten_pos 0 & prelisten while_pressed</pad8>
<pad4 name="BPM x2">set_bpm 200%</pad4>
<pad5 name="Pitch Reset 5%">pitch_reset 5%</pad5>
<menu />
<pad11 />
</page>
geposted Sun 11 Jun 23 @ 10:34 pm
