Topic: Bug in: setting 'stemsRealtimeSeparation' Reduced quality
Hi!
I wanted to implement:
into my skin.
But somehow it seems like I can't query it and/or the command doesn't set the setting as expected.
geposted Fri 16 Jun 23 @ 9:43 am
You would need quotes, since there's a space between reduced and quality
geposted Fri 16 Jun 23 @ 9:53 am
Oh I see...
Ok, worked!
Thanks! :D
geposted Fri 16 Jun 23 @ 9:57 am
