Topic: online music search order
Hi Everyone,
I've been trying to figure out how to adjust my settings so when I type a song into the search bar it will look for music in my local database first, then the iDJPool and then Deezer (in that order). Currently if a track isn't on my local drive it will only search on Deezer and ignore the iDJPool. A previous version used to give results from both Deezer and the pool.
In my settings the search order says (cuaudio, deezer). Can anyone help?
geposted Thu 29 Jun 23 @ 3:44 am
Check the menu dot to the Right of the search bar, and check if the search options are configured as you like, (especially "Online Catalog Options")
Hope that is what you are looking for.
All fixed. Thanks
