Hello,
I only use the ModernEQ setting on the equalizer and do not require the other 2 settings. However, I often find during mixes that it "jumps" to EZ or Frequency, often with the low turned right down, ruining the sound. Is there a way to select or lock the ModernEQ setting?
Due to my current situation I am mixing purely on a laptop, mouse and headphones and suspect that I am double-clicking and changing the settings accidentaly.
Thanks.
Thanks.
geposted Fri 30 Jun 23 @ 12:01 pm
It doesn't really "jump" unless you ask it to...
Connecting new hardware, resetting things and so on can cause it - and of course if it's mapped somehow
What you can do if you like, is to set in on startup, so that VDJ always starts in a specific EQ mode
geposted Fri 30 Jun 23 @ 12:23 pm
Thanks for your quick reply. I always check before a mix that the settings are correct and throughout the mix but ata some point it's back . I'm sure Im double-clicking the mouse, when attempting to simply turn the various knobs. Thanks again
geposted Fri 30 Jun 23 @ 12:29 pm
