Topic: Beat Grid not saving?
Hello,
I often find that the beat grid is misaligned and needs manual adjustment (often on human percussion tracks). However, when returning and cueing up the tracks for play, the beat grid is often back to its original "wrong" setting. This includes when pressing the Tap button to corret the grid
Is there a way to lock the manually adjusted beat grid, so it saves in a simlar way to stems?
Thanks.
geposted Fri 30 Jun 23 @ 12:08 pm
They should automatically save
Are you sure you don't have issues with VDJ being allowed to save your database and settings?
If so, that's usually because of file rights
geposted Fri 30 Jun 23 @ 12:35 pm
OK, I think I've made the adjustments to the VDJ folder. Thanks for your quick and helpful responses.
geposted Fri 30 Jun 23 @ 5:03 pm
