In the Process of preparing stems my system crashes…I have the prepared stems showing in my file folder but the file folder within vdj doesn’t show anything and the songs I did process doesn’t have the blue icon next to the file… I’ve tried physically moving the files from the file folder to the folder within vdj nothing happens….running a dell laptop without the update because the update won’t load tracks in the deck even when hardware is connected…I’ve reinstalled vdj v2023 b7555 and nothing appears in the prepared stem folder…I did not use the default folder the stems would’ve taken up to much space on my internal hard drive so I set the file up on an external hard drive… it worked for my last dj set but 2 days after vdj crashed and everything that has been processed over the past 7 days leading up to that gig is gone…not sure what to do
geposted Tue 04 Jul 23 @ 12:50 am
