Topic: raneone ,the track slides back when scratching
hello, i have a problem with my raneone. when i try to do some very narrow scratches like baby scratch , the song loses the position and slides back. I tried to upload a video to show the problem. this is very annoying because you always have to correct . can anyone help me to solve? Thank you.
macbookair m1
virtual dj 2023 b7594
link video : https://www.youtube.com/shorts/soY-tV6ODMM
geposted Thu 06 Jul 23 @ 2:02 pm
We ll have a look shortly
geposted Thu 06 Jul 23 @ 4:15 pm
thank you
geposted Thu 06 Jul 23 @ 5:55 pm
I tried to reproduce but could not (in both Windows and Mac), at least with the default Settings of VirtualDJ.
Can you reset (rename/delete) your VirtualDJ settings and try again ?
In your video, Deck was playing (and platter hold) or paused at Hotcue ?
geposted Sat 08 Jul 23 @ 5:12 pm
HI . Thanks for taking an interest in my problem. in my deck the platter is active . when the platter is off the problem does not occur. I tried resetting the settings but was unsuccessful. I don't understand what could be causing it.
geposted Sun 09 Jul 23 @ 5:59 pm
I have the same problem on both decks
geposted Sun 09 Jul 23 @ 6:32 pm
hi, i found the problem. I downgraded starting from versions 7561 , 7563 , 7567 , 7572 , 7582 , 7584 , 7594 , 7600.
the problem occurs in the version: 7594 and 7600
Could you notify the development center? Thank you.
geposted Mon 10 Jul 23 @ 4:30 pm
You get the same drift if Pitch fader is at center ?
geposted Mon 10 Jul 23 @ 4:49 pm
Managed to reproduce. Will be fixed soon
geposted Mon 10 Jul 23 @ 6:37 pm
i just installed the update to version 7606. the problem is solved. congratulations to all the virtual dj staff for the speed of resolution and for the attention to the customer. for me it is always the best program in the world.
geposted Tue 11 Jul 23 @ 2:53 pm
