anyone know how to clear the cashie
geposted Fri 07 Jul 23 @ 5:07 am
download ccleaner the clean portable version
geposted Fri 07 Jul 23 @ 9:39 am
Personally I woudn't let ccleaner near any computer.
That will not clear your Tidal cache. Suggest you wait until one of the tech support team responds.
geposted Fri 07 Jul 23 @ 9:58 am
There is no cache for Tidal, so nothing to clear.
It's possible that you added a Tidal link to a playlist or it was added to the search db, in which case you can right-click and remove from search db in case it is a song that Tidal removed.
If it is a song that came up on a new search, then it would be useful to let us know which song specifically.
Edit: And indeed I would stay clear of CCleaner and similar. I think some older version even completely removed the VDJ folder, so that would remove all your database, history, playlists etc...
geposted Fri 07 Jul 23 @ 1:06 pm
In my experience it's usually just one instance of a track that may not load.
Streaming sites have hundreds/thousands of duplicates, so if a track doesn't load from wherever you found it originally, there's usually another copy elsewhere that will load.
geposted Fri 07 Jul 23 @ 5:43 pm
I had that problem too when I used the service. Pretty sure it's an issue at their end.
geposted Fri 07 Jul 23 @ 6:24 pm
ty
geposted Mon 10 Jul 23 @ 7:06 pm
ty i been trying to fix this for abit now to
geposted Mon 10 Jul 23 @ 7:07 pm
