After I installed early access 7600, "search in history and playlists" no longer worked.
Only after I did a repair via b7555.msi did it work again.
I've often noticed that it sometimes takes a long time for results to appear in the search list. Sometimes only after the second or third search via the "search_playlists" action button.
But maybe this is normal after the first start.
Does anyone have the same problem?
geposted Sun 09 Jul 23 @ 5:46 pm
Works from the first time for me with 7600
The first search will indeed be a bit slower as it's still reading all the playlists, but you should see the progress bar in the search_playlists window to let you know if it's still working on it
geposted Sun 09 Jul 23 @ 6:19 pm
"search history and playlists"
How do we do that?
How do we do that?
geposted Sun 09 Jul 23 @ 7:12 pm
Assign a custom button to search_playlists and it will create a list of playlists and history for the highlighted track in the browser
Also working fine here on b7600
You can also search your history by saved name the same way by using search_folder
geposted Sun 09 Jul 23 @ 7:42 pm
