Topic: Cannot delete [value] in first Hotcue pad
Hello, in VDJ, there are 8 Hotcue pads, but I cannot delete what is in the first pad. It says [value]. It seems that one is used as a system default which cannot be deleted. Is this correct?
geposted Mon 10 Jul 23 @ 12:40 pm
No, I can delete all of them
There must be a setting I am missing. Thanks.
Perhaps u changed the default Hotcues pad page and u have some error in 1st pad ?
Try to open Pads Editor and reset it
OK fixed it. I went into the Pads Editor and edited Pad 1 which did not have any Push Action. Thanks.
