Every time I open VDJ I get this pop up in the lower right corner.
I am not connected to the internet. If I connect then it goes away.
How can I get this to stop?
geposted Tue 11 Jul 23 @ 4:08 pm
is that tip of the day?
if so turn it off in settings.
if it's not tip of the day then it's home user ads, keep your machine logged in
geposted Tue 11 Jul 23 @ 4:13 pm
Not tip of day. This is a backup laptop, never had this before.
Usually is offline
Usually is offline
geposted Tue 11 Jul 23 @ 5:34 pm
Check to see if it's logged in.
geposted Tue 11 Jul 23 @ 5:50 pm
This laptop is not logged in. Inly log in to update. This never happened before.
geposted Wed 12 Jul 23 @ 2:52 pm
Maybe you were just lucky then. Generally if you're logged out it then reverts to free mode which displays ads.
geposted Wed 12 Jul 23 @ 3:08 pm
Main system also never logged in, use it with no problems.
No internet where I use it.
geposted Wed 12 Jul 23 @ 3:10 pm
What I mean is the laptop "logged in" to VirtualDJ and staying logged in. You don't need internet access once you have logged in except if you ask it not to remember you.
If the software thinks you are a "free" version user it will display ads.
geposted Wed 12 Jul 23 @ 3:13 pm
Got it. The strange thing is, it's set to remember.
geposted Wed 12 Jul 23 @ 3:21 pm
Which version is on there? I don't think there should be ads for a while now.
geposted Wed 12 Jul 23 @ 3:50 pm
Standard release 7555
geposted Wed 12 Jul 23 @ 4:21 pm
It stopped doing this for a few days: now it's back again.
geposted Sun 16 Jul 23 @ 5:47 pm
Try renaming your settings.xml file with VDJ closed then log in again and see if it happens with a newly created one.
geposted Sun 16 Jul 23 @ 6:04 pm
That seems to have stopped it.
Hopefully it stays this time.
Thanks
Thanks
geposted Mon 17 Jul 23 @ 1:53 pm
