as seen in the image
currently the "apply to" seems to go on all the effects at the same time including the filter knob
so this makes it a little difficult to use in practise having to turn it on and off as you need it
being able to set and forget for each effect slot would be better i think.
an altnerative might be to have a dedicated effect for each stem "reverb -vocal" "echo out- vocal" "cut- drums" etc...... that would be better in a sense because you could have different versions of the same effect loaded at the same time, applying to different stems , but it would mean there would have to be multiple versions of every effect, the menu would get very big
geposted Fri 14 Jul 23 @ 1:04 pm
