I am doing some additional maintenance with my library and originally had wiped out my remix field to be blank, and then eventually added CLN and XPL fields in there. But I am looking to reload all my data back in from the track field.
But this does not seem possible without some changes in file structure.
If I remove a song from the search db, then re-add, it ignores the remix field all together.
If I ask it to reload tags, nada.
Even if i remove, move the files to another location, then re-add, nada.
I see it uses the Album Version tag as the Remix tag but only seems to write it if it's a FLAC file. mp3 not supporting that tag?
Thoughts?
Thoughts?
geposted Fri 14 Jul 23 @ 4:35 pm
I think it uses subtitle in MP3 for remix
geposted Fri 14 Jul 23 @ 4:44 pm
Right you are, subtitle for mp3.
m4a/ALAC seems to be database-only.
geposted Fri 14 Jul 23 @ 5:01 pm
For m4a should be subtitle too
geposted Fri 14 Jul 23 @ 5:04 pm
Unfortunately VDJ has some limited m4a support. I noticed this with a couple other tags a while back (https://virtualdj.com/forums/239045/VirtualDJ_Technical_Support/m4a__some_specific_tags__and_VDJ_.html) I don't think VDJ has the option to support it.
geposted Fri 14 Jul 23 @ 5:13 pm
So now the question is, is there any way to do this natively in VDJ other than essentially wiping the database and starting fresh? Which technically I can do, but really don't want to unless there are no other options.
geposted Fri 14 Jul 23 @ 7:03 pm
