Topic: How can I echo out to next deck.
Hello,
When I use the echo out effect on deck 1 to transition into a song playing on deck 2, the echo out stops as soon as I switch is all the way over to deck 2 (and vice versa). However, I want it to continue playing so it's more of a smooth transition when I switch songs/decks.
How can I fix this?
Thank you!
geposted Tue 18 Jul 23 @ 5:04 pm
check the option for fxProcessing
Sorry, I'm still new to virtual dj. I checked the options and couldn't find fxprocessing. I also searched for it in the settings. Where exactly is it located?
Thank you
Thank you. However, I switched it but it's still not working. I even tried restarting and trying again
Nevermind, it's working now. Thank you!
