Hi there,
i'm wondering where to find the skin files for the CDJ3000 as shown in the hardware manual section. There are no such files in the plugins.
Can I download those files somewhere without the need to plug in a CDJ3000?
Thanks in advance
Jochen
Thanks in advance
Jochen
geposted Wed 19 Jul 23 @ 7:42 am
If a DDJ-3000 has already been plugged in and used once (and it requires a skin for the screen, which I assume it does), then the skin files will have been auto downloaded to the /skin subfolder of your VDJ home folder
For instance I have a Numark Mixstream Pro, so in my skins folder there is a "Numark Mixstream Pro Screen.zip" file that contains the needed skin files for the Mixstream screen
geposted Wed 19 Jul 23 @ 7:58 am
I know, but I have no CDJ3000 at the moment and haven't had plugged in so far. Maybe somebody can send mit the XML files of the skin?
geposted Wed 19 Jul 23 @ 8:19 am
There's no skin for the cdj 3000, the layout of the screen is fixed by the firmware
geposted Wed 19 Jul 23 @ 9:31 am
Hey Adion,
thx for the information. 👍
geposted Wed 19 Jul 23 @ 9:50 am
