Been using the old looking VDJ 8 skin way too long, and thought I would finally try one of the newer updated versions, such as the " performance" skin.
Still using VDJ 8 (build V.4 b5874)
Mac Pro 2015
Tested new skin on my old PC (still running windows 7) and it works fine, went on to my MAC Pro 2015 ( to which was recently updated to Monterey)
Will not work entire software freezes each time and I have to do a force shut down - Bummer!
Any fixes I am not aware of?
Cheers and thanks for some guidance advice!!
DJ Andrea
Mac Pro 2015
DJ Andrea
geposted Thu 20 Jul 23 @ 10:09 pm
