Topic: Sampler Instruments sync failure
when using the sampler's instruments in some tracks, the sync fails , usually on older recordings. I understand that in older recordings sometimes the drums drift. Is there a way to correct this? I have tried both BPM and Multiple BPM analysis but it didn't work. I also tried all option in Mode and Loop in the Sample Editor. If case it matters, i use an older edition (5874) of the software. Thanks
geposted Fri 21 Jul 23 @ 10:09 pm
My recommended method for correcting tempo drift on retro tracks is to warp them in Ableton Live.
Unfortunately this is not something that DJ software is capable of - although I'd love for VDJ to be first out of the blocks.
Thanks
It would be an even better idea to pitch your samples and start them manualy. So you could sync your samples manualy.
