Topic: Saving EQ and Gain settings
Whenever I exit the program and restart it, I lose my EQ and Gain settings. I want the EQ (Hi, Mid and Low) and Gains to stay the same for all tracks. Is there a way to do this in Mapping? I appreciate any assistance.
geposted Mon 24 Jul 23 @ 9:41 pm
Are you using a controller as the software will follow the physical knobs.
If not you can set an oninit command in the keyboard mapping to set what you want to happen when the software starts up.
Yes I am using a controller. I didn't see how to do this in Mapping.
then you want a master eq fx, channel eq's are not made to be a permanent setting.
Can you please provide me with an example command or script? I simply want the gain and EQ knobs in the skin to be at certain levels when I start the program. I tried in mapping but could not get the knobs in the skin to move where I want them.
For example, I want the EQ knobs to be at High 137%, Mid 137% and Low 164% for both decks. I also want the Gains to be at -1.71db for both decks.
