Topic: DMX Fader send Midi custom fader like vu meter
Hello, i want to send a midi signal to daslight to controll there the master fader.
This works over the custom fader in vdj with the freestyler plugin.
But next i want to use the level meter to send like:
get_level_peak & param_multiply 220% : set '$FS_FOG_FAN_LEVEL'
But then i dont see a midi signal in midiviewer.
geposted Tue 25 Jul 23 @ 1:30 pm
Are you using the MIDI plugin ?
If so you should directly map the SEND_FOG_FAN_LEVEL key to get_level_peak & param_multiply 2.2
Bit how i get Send this command to my loopmidi Port?
I use the freestyler Plugin, then i map the commands i get to DasLight.
So i have a Custom Button for start, Switch Forward, Blackout, all White and some Others. But now i want to have a fader and ITS sems Like Tricky for me.
And the next step will BE, that the fader only Change from 100% to 50% Minimum and that IT have to start with 100% because in DasLight the fader Position at the beginn IS at this point.
Its funny, but my sollution ist Like the same.
Because i switch from freestyler to DasLight.
But how get i the Signal of the Level as a command in the freestyler Plugin?
The normal Buttons are working.
