Hello, I just got a Brand New Alienware Monitor. It's the AW3423DW which is the 34" curved qd-oled and it's at 4K Resolution. I scaled my Windows 11 up to 150% and now when I go into my VDJ Software the skin is no longer full screen it's like abit more than half the screen I would say. If I go back to the Default Skin its full screen, then change back to project x slider and it's also full screen. However, when I close the software out and reboot it's no longer full screen ugh what am I doing wrong, or it is just not compatible maybe? Thanks!
geposted Tue 25 Jul 23 @ 6:26 pm
Not sure this can be skin related because, as you say, when you change the skin and change it back it displays as expected.
Does the monitor have any settings - some of these large monitors by default only open to half screen as they are designed for 2 or more things to be opened.
geposted Mon 14 Aug 23 @ 9:51 pm
