Topic: Automatic stem 2.0 create when loading track
Hallo, I have the following question:
Is it possible with VDJ to automatically create a stem 2.0 version of a track on the fly when it is loaded onto a deck, or is it always necessary to first prepare the stems?
Cheers
geposted Sun 30 Jul 23 @ 10:08 am
Yes assuming your machine is powerful enough to process the stems.
Thank you for the answer, Kradcliffe.
I have just recently got my hands on a 2023 MacBook Pro with M2 Pro processor and 32 GB Ram, so I guess it is definitely powerful enough.
Could you explain what I have to do in order to have VDJ create the stems automatically?
Cheers
Default settings should do it already, but if not, simply set stemsRealtimeSeparation to Always
Ah okay, thank you! This option is already activated.
I thought I had to activate something else.
Quality with stems is already pretty good. But I thought it could be even better.
Anyway, thanks for your help!
