I wanted to see if anyone else had seen a problem with their virtual dj GUI flashing when in full screen mode. It's usually triggered by a right click which brings up the contextual menu, but then left clicking off of it.
It doesn't appear to affect the playback, but really freaks me out that something might crash anytime soon...
It doesn't appear that this happens in a expanded window or movable window, only full screen mode from what I can tell. I reinstalled about 5 times to see if I could get rid of the problem... no luck.
here's an example (hopefully this links correctly):
https://photos.google.com/photo/AF1QipP2W1OpqfbMhZcKEhhV3GxLqKiWN6te979VHRJh
geposted Tue 01 Aug 23 @ 4:39 am
Try to install the latest graphics drivers for your GPU
geposted Tue 01 Aug 23 @ 5:30 am
Unfortunately that didn't help - updated all GPU drivers.
geposted Wed 02 Aug 23 @ 12:11 am
FYI, there is a setting EXPERIMENTALSKINENGINE that is set to Auto (with my defaults). Setting it to "No" solved the problem.
Following up with Virtual DJ technical support - but thanks for the initial work-around!
geposted Thu 03 Aug 23 @ 6:34 pm
Another quick update, it does appear that you have to go in and install the geforce experience and do a custom install (clean update option) and it solves the problem.
geposted Thu 03 Aug 23 @ 10:21 pm
Just a note. It's October 2025 and I just upgraded from Windows 10 to Windows 11 and encountered this same issue.
VirtualDJ app and other Windows Desktop apps were having the blank screen flicker after the upgrade to Windows 11.
Yes! This fix from 2023 Fixed My Problem!
Open Nvidia app (Was called Nvidia Experience) > Drivers > Reinstall > Custom Installation > Check the box : Clean Installation.
Thank-you so much for the fix!
Nvidia Rtx 2070
AMD 5800x3d
Keep if Funky!
Nvidia Rtx 2070
AMD 5800x3d
Keep if Funky!
geposted 18 hours ago
