Is there a script or some setting to automatically assign a recording filename base on date and time? e.g. 2308051513
geposted Sat 05 Aug 23 @ 5:15 pm
make filename
%date%time
%date%time
geposted Sat 05 Aug 23 @ 5:41 pm
Simple enough. Thanks.
geposted Sat 05 Aug 23 @ 7:23 pm
locodog wrote :
make filename
%date%time
%date%time
is there a way to show the date in the UK format of Day Month Year?
geposted Sun 06 Aug 23 @ 8:16 pm
YYYYMMDD is superior as it date sorts with alphabetising the file names
but if you want to open yourself to less than optimum naming
You'll have to set it with script for now
[@devs seems dataFormat setting doesn't change %date]
This is an example local for me
or
you could make it part of your oninint so the name is formatted ready when you press record
set $dateString `param_add 'get_date "%d-%m-%Y"' 'get_text "C:\Users\user\Desktop\"'` & set $dateString `param_add 'get_text ".mp3"' 'get_var $dateString'` & get_var $dateString & param_cast & setting recordFile
or
get_text "c:\Users\user\Desktop\`get_date '%d-%m-%Y'`.mp3" & param_cast 'text' & setting recordFile
geposted Sun 06 Aug 23 @ 8:44 pm
Cheers LocoDog
geposted Sun 06 Aug 23 @ 9:05 pm
