Hello,
I wanted some POI/Scripts to run only when played on decks 3 or 4, therefore when the track is played in decks 1 or 2 the POI should be ignored. So far I've tried the deck # play ? approach, which kind of works, but it has some flaws if both decks are playing, the POI is executed when deck 1 reach it no matter the position of deck 3 or 4, only when decks 3-4 are stopped the deck 1-2 ignores de POI.
It's even possible? If so, please help me to point me in the right direction. Thanks.
geposted Wed 09 Aug 23 @ 3:38 am
would action_deck x ? work for you?
Say, you wanted a 16 beat loop to only occur if the track was being played on deck 3 or deck 4, and nothing when on deck 1 and 2.. then something like.. may work.
OR
of the general form:
action_deck 3 ? loop 16 ? nothing : loop 16 : action_deck 4 ? loop 16 ? nothing : loop 16 : nothing
OR
action_deck 3 ? POI ACTION : action_deck 4 ? POI ACTION : nothing
geposted Wed 09 Aug 23 @ 4:06 am
geposted Wed 09 Aug 23 @ 5:00 am
geposted Wed 09 Aug 23 @ 5:05 am
This is gold and it's exactly what I was looking for.
Thanks a lot!
Cheers!
Thanks a lot!
Cheers!
geposted Wed 09 Aug 23 @ 5:11 am
Hi5 !
geposted Wed 09 Aug 23 @ 5:14 am
