Macbook Pro 2011
I7
6gb de RAM
SD 120gb
HDD 500gb
MacOs Mojave... but it can be updated to Monterey...
I will use only for Virtual DJ with a DDJ-SB1...
I7
6gb de RAM
SD 120gb
HDD 500gb
geposted Fri 11 Aug 23 @ 2:49 pm
geposted Fri 11 Aug 23 @ 3:03 pm
I mean, do you think its gonna run smooth? fine? i know sometimes it have support, but the software working wit crashes and bugs if you know what i mean...
geposted Fri 11 Aug 23 @ 5:25 pm
Depends how much crap you have on the machine and whether it's optimized or not.
geposted Fri 11 Aug 23 @ 5:31 pm
You should be able to run an older version of vdj I have a 2010 that I bought new and used for many years It still works and runs vdj You'll need at least 8 gig of ram . Don't expect to run video or run Multiple effects
geposted Fri 11 Aug 23 @ 11:22 pm
