Topic: Script help: load songs in stems_split mode w ONSONGLOAD
Wish to have a script that could be added to the KeyBoard: ONSONGLOAD mapping to automatically load the track in stems_split mode.
It appears that one needs to be careful, since the process of creating the "split stem" on the lower deck is also a seen as another Song Load.. so easy to create in infinite loop, or unsplit the track w the second song-load.
scripts that have no joy, are: (just attempting half the script for deck 1)
wait 2000ms & stems_split
deck 1 load_pulse ? nothing : deck 1 stems_split
deck 1 ? deck 1 stems_split : nothing
action_deck 1 ? deck 1 stems_split : nothing
deck 1 loaded ? wait 2000ms & deck 1 stems_split : nothing
deck 1 stems_split ? nothing : deck 1 stems_split
etc
maybe use load_pulse to toggle a variable, wait.. then do the stems_split ? Need some help.
the trick is to allow the initial song-load to initiate the stems_split.... and then to stop the loading of the "split" from repeating the same action.
And trying hard NOT to HANG VDJ.
Any help, suggestions appreciated :)
is this possible?
am I overlooking maybe a built in feature that would do this?
Thanks for the help :)
geposted Sun 13 Aug 23 @ 2:53 pm
why not query the deck
param_bigger `get_deck` 3 ? nothing : do the thing
geposted Sun 13 Aug 23 @ 2:59 pm
Awesome idea locodog.. a much better way to approach the scripting.. many thanks for your amazing insight.
for some reason param_bigger `get_deck` 3 ? nothing : deck 1 stems_split did not work as expected and would hang VDJ if a track was loaded to deck 3.
and seems with your approach.. that something like:
param_equal `get_deck` 1 ? wait 1000ms & deck 1 stems_split : nothing
works for deck 1..
so seems it may be possible after all, woot !
making progress !
Again many thanks !
geposted Sun 13 Aug 23 @ 3:37 pm
param_bigger with 3 would only be true for deck 4, so probably want to check bigger than 2
geposted Sun 13 Aug 23 @ 3:51 pm
my mistake,
I'm getting weirdness that it needs a wait in there, without the wait my variable toggles but I don't get a clone
param_bigger `get_deck` 3 ? wait 100ms & stems_split & toggle $proof :
geposted Sun 13 Aug 23 @ 4:10 pm
Thanks Adion .. have not tried that.
And thanks Locodog for the amazing idea !
Have got a script now that works, posting in case it's of interest to others:
var '$LoadSplitStems' 1 ? param_equal `get_deck` 1 ? wait 500ms & deck 1 stems_split : param_equal `get_deck` 2 ? wait 500ms & deck 2 stems_split : nothing : nothing
the above script would be added to the keyboard ONSONGLOAD mapping.
and one would need an additional custom button/skin button/controller button with script:
toggle '$LoadSplitStems'
which just turns ON or OFF the "Split Stems auto-loading" feature.
Additional behavior:
If one adds a track to the lower decks (3 or 4) then the split stems mode ends for the track on the upper deck, so a lower deck track can be played if wanted.
(and loading a track to upper deck, say deck 1, a playing track on deck 3 is NOT interrupted with a split stems load attempt, so the stems_split for deck 1 will NOT occur if deck 3 is audible, and playing another track, [when this feature is enabled].)
All seems to work well.
Note: if using a controller button, then great to have LED feedback if the feature is enabled, w something like this for the LED Mapping:
var '$LoadSplitStems' 1 ? on : off
or
var '$LoadSplitStems' 1 ? blink : off
geposted Sun 13 Aug 23 @ 4:22 pm
why deck specific?
var '$LoadSplitStems' 1 ? param_bigger `get_deck` 3 ? wait 1ms & stems_split : nothing : nothing
is 3 bigger than calling deck ? yes, split it
geposted Sun 13 Aug 23 @ 4:38 pm
Wow Locodog .. once again... a clever script..
yes that would work perfectly and, with fewer queries..
PS
did not test the minimum wait time for script to work.. .. wow 1ms, is all that is required.
Again thanks.
geposted Sun 13 Aug 23 @ 5:01 pm
