Topic: After renaming Set Recording filename, all cue points were lost
Hi,
I've recorded multiple sets lately.
It saves them by the default name "Recording Set".
It creates a new file every time with a "(1)" added to the filename if the original already exists.
When I play the set, I can see the cues of all the different songs that were played and can walk through them.
I tried renaming the files today not via VDJ, and since then I'm unable to get my cues back to the set recording!
When I look at the POI Editor, I see all the original cue points now exist as "BeatGrid Anchors" instead and are all named "Beat Anchor".
I tried renaming it back to the original name ("Set Recording"), I tried playing with the auto-created .cue file and rename the filename there as well as inside the file on the 3rd line ("FILE "Set Recording" MP3").
Nothing works, it seems the VDJ db is adamant of deciding this is a different file when I look at the tag editor.
How can I salvage those cue points?..
Thank you.
geposted Sun 20 Aug 23 @ 12:08 pm
