<?xml version="1.0" encoding="UTF-8"?>
<page name="Tone">
<pad1 name="C">effect_beats 'mt delay' 0.12232</pad1>
<pad2 name="D">effect_beats 'mt delay' 0.10899</pad2>
<pad5 name="G">effect_beats 'mt delay' 0.08163</pad5>
<pad3 name="E">effect_beats 'mt delay' 0.09708</pad3>
<pad4 name="F">effect_beats 'mt delay' 0.09161</pad4>
<pad6 name="A">effect_beats 'mt delay' 0.07272</pad6>
<pad7 name="B">effect_beats 'mt delay' 0.06478</pad7>
<pad8 name="C">effect_beats 'mt delay' 0.06116</pad8>
<shift_pad1 name="C#">effect_beats 'mt delay' 0.11547</shift_pad1>
<shift_pad2 name="Eb">effect_beats 'mt delay' 0.10282</shift_pad2>
<shift_pad3 name=" "> </shift_pad3>
<shift_pad4 name="F#">effect_beats 'mt delay' 0.08650</shift_pad4>
<shift_pad5 name="G#">effect_beats 'mt delay' 0.07704</shift_pad5>
<shift_pad6 name="A#">effect_beats 'mt delay' 0.06863</shift_pad6>
<shift_pad7 name=" "> </shift_pad7>
<shift_pad8 name="C#">effect_beats 'mt delay' 0.05773</shift_pad8>
</page>
First stage of an idea, turn mt delay on and get some tonal delays.
Not sure on anything yet, just something for those that like experimenting, I might do a few octaves worth.
geposted Mon 21 Aug 23 @ 7:33 am
Crazy stuff :)
geposted Tue 22 Aug 23 @ 1:23 am
<page name="Tone Delay">
<pad1 name="C">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.12232</pad1>
<pad2 name="D">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.10899</pad2>
<pad5 name="G">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.08163</pad5>
<pad3 name="E">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.09708</pad3>
<pad4 name="F">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.09161</pad4>
<pad6 name="A">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.07272</pad6>
<pad7 name="B">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.06478</pad7>
<pad8 name="C">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.06116</pad8>
<shift_pad1 name="C#">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.11547</shift_pad1>
<shift_pad2 name="Eb">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.10282</shift_pad2>
<shift_pad4 name="F#">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.08650</shift_pad4>
<shift_pad5 name="G#">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.07704</shift_pad5>
<shift_pad6 name="A#">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.06863</shift_pad6>
<shift_pad8 name="C#">effect_active 'mt delay' while_pressed & effect_beats 'mt delay' 0.05773</shift_pad8>
<param1 name="Strenght">effect_slider 'mt delay' 1</param1>
<menu>`effect_show_gui 'mt delay' `</menu>
<param2 name="Trailing Stop">effect_button 'mt delay' 1</param2>
</page>
geposted Fri 25 Aug 23 @ 4:24 pm
I was thinking about having the fx latch on, with 2nd press of a key turning the fx off but fx beats doesn't query correctly with such small floats, it could still be done with vars but this was a 5 minute of fun idea.
geposted Fri 25 Aug 23 @ 5:27 pm
I think it works fine as Stutter Effect with Key Change ...
I have FX on while pressed , because i think than don't must Load an start this FX in a Slot ...
The Strenght you can change with Parameter .
geposted Sat 26 Aug 23 @ 3:49 am
