Ok so i use this skin when broadcasting http://www.virtualdj.com/plugins/index.html?addonid=81125
Right now it only lets me select "SlideShow" for the background in the options. I want to use the "Shaders". How can I set this??
As you can see in my video its using slideshow which gets boring, Id rather have the shaders.
Any help would be greatly appreciated.
geposted Mon 21 Aug 23 @ 2:46 pm
What do you have in OPTIONS for VideoAudioOnlyVisualization ?
(Also selectable from the VIDEO FX (or SOURCE) drop-down in Video panel.
If not affected, perhaps there is something in the Video skin.
geposted Mon 21 Aug 23 @ 2:52 pm
Found it...
Map a button as ..
set '@$broadcasterGFXbackground' 2 & deck 3 video_fx 'shader'
Map a button as ..
geposted Mon 21 Aug 23 @ 3:11 pm
Download the Broadcaster GFX performance pads
there you can choose background to use, including Shaders
Shaders needs to be set on deck 3 though
See here
https://virtualdj.com/wiki/BroadcasterGFX.html
See here
See here
See here
Ok when I have set them on deck 3 they dont really seem to react to the music since im using deck 1 & 2
geposted Mon 21 Aug 23 @ 3:13 pm
Can download this pads to control everything
https://virtualdj.com/plugins/index.html?addonid=81122
geposted Mon 21 Aug 23 @ 3:14 pm
the SOUND INSURGENT wrote :
Yes, for sound aware ones, you could route the master back as AUX to deck 3
Currently the shader background is a bit of a "work around", but maybe we can add direct support (currently it supports slideshow and deck as background sources, so deck 3 as unused deck, was a way to use shaders for now
geposted Mon 21 Aug 23 @ 3:16 pm
Ok that makes sense now. And yes, I do use the pads. Just the background was bothering me but its ok.
Ill just have to up my slideshow game some more lol!!
geposted Mon 21 Aug 23 @ 3:17 pm
