Topic: Saved loops not showing on controller touchpads
I have saved loops on some songs. When I switched to a new computer and controller board, I see the saved loops on the VDJ software screen but when I select the saved loops touchpad setting (on a Rane Four) it shows blank like it has none. Is there a fix? Thanks
geposted Tue 22 Aug 23 @ 4:11 am
Can you post some screenshot of your VirtualDJ GUI showing the Saved Loops of a Track ?
From VDJ Settings->OPTIONS tab, the setting padsSkinIndependent is set to No, correct ?
And from your Rane Four you press SHIFT+ROLL mode to get the Saved Loops, correct ?
Ok I went to do a screenshot then I realized what's happening: Saved Loops (shift loop roll on Rane 4) does not set it to saved loops - it sets it to Loop. So it's mis-configured by default but I can change that pretty easy. So thanks. Just maybe it should be noted by someone to fix that default.
