My Denon MC6000MK2 crossfader does not fade out the song from one deck to the other completely,. If I move the (hardware) crossfade 100% to another song you can still hear the first song playing from the other deck. If I take the crossfade back just a bit to 95% it will then cut out the first song. Any suggestions what is causing this problem?
geposted Tue 22 Aug 23 @ 7:11 pm
fader bleed, try clean the fader if that doesn't fix it then you need to replace the fader, faders don't last forever.
geposted Tue 22 Aug 23 @ 10:02 pm
