Topic: Support for Denon Prime 4+
J@vierCPRO InfinityMember since 2014
Hi , is the Denon Prime 4+ running with VDJ? Is the same processor as Prime 4 version ….Thanks
geposted Sun 27 Aug 23 @ 6:59 am
Apparently it's exactly the same unit inside so no update required. Should just work plug and play per the previous Prime 4.
geposted Sun 27 Aug 23 @ 7:50 am
ok, someone has tried?
geposted Sun 27 Aug 23 @ 3:57 pm
Confirmed the Prime 4 plus works ok plug and play , same as Prime 4.
geposted Mon 18 Sep 23 @ 12:36 pm
