so you can using transport mode change the pitch up and down with the pads. but it does it at increments really, really tiny. you have to press the pad like 25 times to move 2 percent. better than nothing. but would be cool if it moved it lets say .5 or 1 percent. not trying to beatmatch per se like this. since im just using a djm 750k and this. i can use the mouse. or sync.
stems, and all that work fine
geposted Wed 30 Aug 23 @ 9:21 am
yes! i types in .5 instead of whatever it was an it works like i wanted.
geposted Wed 30 Aug 23 @ 9:27 am
