I wanted to set up a color rule that highlights any track that was released this year or last year. This work perfectly:
Year >= 2022
But of course I would need to update it every year, I tried to use a verb but noticed it didn't seem to work:
Year = get_date "%Y"
Just wanted to double check if there was a way to do this?
Year >= 2022
geposted Wed 30 Aug 23 @ 7:34 pm
no script in filters currently.
geposted Wed 30 Aug 23 @ 7:43 pm
However days since first seen < 730 should most likely do the trick, no ?
geposted Thu 31 Aug 23 @ 10:56 am
Unfortunately this is not a true fix....this is looking at when VirtualDJ has first encountered the song in its browser. If you do a lot of backfilling of your collection (collection updates by adding songs that have a older date/year), they would show up too.
As @locodog mentioned...if the filters supported the full VDJScript, that may be the solution to the problem.
geposted Sat 02 Sep 23 @ 11:48 am
Ever thought about the following filter folder ?
Top 100 year
It gives you the 100 songs with the highest year ... so probably the current year ;-)
It is not exactly what you want ! But could be an acceptable workaround ?
Top 100 year
geposted Sat 02 Sep 23 @ 1:07 pm
