Topic: [Solved] DDJ 1000 Deck 4 Controls Inaccessible
I'm not sure if this issue is just with my DDJ 1000 controller or not.
I've noticed that when I switch to Deck 4, the access to the deck controls are no longer available responsive, and on the screen I see the general "Rekordbox" text, instead of "Not Loaded":
This is what I see in the mapping editor with the deck switch press:
The Deck 1/Deck 3 switch does the right thing (shows "Not Loaded" and gives access to the deck).
Platform/VirtualDJ Version /Other Info:
  • Platform: M1 MacBook Pro (2020), 16GB RAM, 1 TB SSD
  • VirtualDJ Version: v2023-m b7607
  • I am using the factory default mapping for the DDJ 1000
geposted Tue 05 Sep 23 @ 5:02 pm
Is channel 4 SOURCE select switcher on top set to correct USB port "input" (USB A or USB B) ?
geposted Tue 05 Sep 23 @ 5:46 pm
You were right...it was set to computer B (long day brain fart). Thank you for the reminder...please close the issue
geposted Tue 05 Sep 23 @ 5:56 pm
