Another mistake in B7651 Early Build.
Virtual DJ simply scans tracks when I automatically load them into the player to BPM Key and Gain and simply write in the tags.
Although I switched this off in the Obtions.
As to be seen in the screenshot.
He doesn't do this in 7607 ;-)
geposted Sat 09 Sep 23 @ 2:44 am
Songs are always scanned when loaded to a deck.
The option is about scanning when they are visible in the browser
geposted Sat 09 Sep 23 @ 3:16 am
The songs are all scanned .
But it doesn't scan them again if you switch this off in the options.
I don't mean stem analysis
geposted Sat 09 Sep 23 @ 3:36 am
Ich have try Build 7607 , the it is normal .
It don't analyze when i load , and write in Tags ...
In the early build all tracks in Browser shown as not Analyzed with green Star ....
Thats not normal
Thats not normal
geposted Sat 09 Sep 23 @ 3:40 am
It's just weird.
Now I've installed the early build again, and now it's not like that, it doesn't show the tracks in the browser with a green star as unanalyzed.
And it doesn't rescan when loading into decks or write new values to the tags.
But yesterday I tried Early several times and there was an error.
Then again the 7607 wasn't there.
What could be the reason? Could it be that the early didn't read the database correctly for a short time?
It's strange, isn't it?
But there must have been something about the early
geposted Sat 09 Sep 23 @ 3:59 am
The green star means the songs are new, it doesn't mean they are not analyzed.
So perhaps there was a problem closing VirtualDJ previously, and the database could not be opened.
Normally you would get a notification of this on startup though.
geposted Sat 09 Sep 23 @ 5:48 am
I know that .
I told you, they were all tracks that have been analyzed for ages. On all, every track.
I installed the 7607 and it was gone.
Then the new early again and it was the error again that it showed them all as unanalyzed and re-analyzed each time.
Tried this several times, so it must have been due to the new build.
Just as I'm saying now, I'm installing it today and it's no longer strange with the new build either.
The database itself didn't show any errors, BPM and key were also displayed, but it still kept rescanning and analyzing as if they were new tracks.
geposted Sat 09 Sep 23 @ 6:52 am
