Question about this command > search `get_browsed_song 'title'`
This command returns all artists with the corresponding title in the search bar.
But I would like to pass the following characters " " to limit the search, what should the command look like?
so that the following appears in the search bar > "title" (not like that > title)
thanks !
thanks !
geposted Thu 14 Sep 23 @ 9:37 am
thanks !
thanks !
geposted Thu 14 Sep 23 @ 10:44 am
think this is what you are looking for:
would work in a custom button or mapper or padpage.
if used in a skin, believe that the " would need to be replaced with & q u o t ; (without the spaces) so as not to incorrectly interpreted by the skin xml.
So if the loaded track is Dua Lipa - Love Again
the search field is populated with: "Love Again"
get_text '"`get_browsed_song title`"' & param_cast text & search
geposted Thu 14 Sep 23 @ 1:20 pm
Hi IIDEEJAYII,
Thank you very much, it works great for the title or artist !!!!!
But how do I link both, i.e. title and artist at the same time ?
geposted Thu 14 Sep 23 @ 3:09 pm
do you mean in the above example to have
"Dua Lipa" "Love Again"
in the search field if the loaded track is Dua Lipa - Love Again
That would be:
Or do you want the search to be
"Dua Lipa Love Again"
That would be:
get_text '"`get_browsed_song artist`" "`get_browsed_song title`"' & param_cast text & search
get_text '"`get_browsed_song artist` `get_browsed_song title`"' & param_cast text & search
geposted Thu 14 Sep 23 @ 4:21 pm
@IIDEEJAYII.
The first one is exactly right for me !!!
thanks Werner
thanks Werner
geposted Thu 14 Sep 23 @ 5:02 pm
