Forum: Wishes and new features
Topic: Standard Pad Page for auto_bpm_transition?
Now that the auto_bpm_transition feature is in a public release, could there be and "official" pad page downloadable under extensions to setup/trigger some of all the things it can do?
Maybe an emulation of the buttons for it on the rev5?
... just so that everybody don't need to script something themselves :)
geposted Thu 14 Sep 23 @ 9:09 pm
+1
It would be awesome if maybe some of the new features could eventually be integrated into VDJ's automix, at some point, to extend automix's capabilities.
(maybe already in the works)
Are there more details on the auto_bpm_transition as google doesn't give much info...
Basically it adds a similar feature to what "Auto BPM Transition" is on the rev5 - here demonstrated by Phil form DDJT (stating around 2:05)
I did this quick example in VDJ a few weeks back, where it sets the length of the transition change to 16 bt, starts a loop (with current loop length of 8 bt), turns off all stems except drums and starts the auto bpm transition. After that the second tracks is started manually in time (before the bpm transition is fully done), and the crossfader is used to fade in the next track
The script used is
auto_bpm_transition_options length 16 && auto_bpm_transition_options loop on && auto_bpm_transition_options stems vocal off && auto_bpm_transition_options stems instru off && auto_bpm_transition_options stems bass off && auto_bpm_transition
I plan to do a better video at some point - but I think a standard pad page for it would be a great addition :)
We just uploaded one, will be available in a few minutes
Pad 1 ON : Turn Auto-BPM Transition on/off
Pad 3 MT : Enable/disable MT on/off during transition
Pad 4 LOOP : Enable/disable a Loop during transition. It's using the current loop size
Pad 5 to 8 : Decide which Stems will be kept during the transition
Param 1 : Select the duration of the BPM Transition in beats (how much time one deck will need to reach the BPM of the other one)
MT? That button doesn't seem to do anything here.
The stems buttons seem strange too. Once clicked, I can't revert back by clicking again.
MT is master tempo. If you disable it, you can have i do some pitch play as part of the transition 🙂
Cool! Thank you!
Oh abt has gone public, (I should pay more attention) probably worth a script school update.
These are not normal On/Off Stems buttons, but the auto-BPM-Transition parameters.
We didnt force Stems to return to original status after Transition is done, since we assume that another song will be loaded to the first Deck, and Stems will be reset anyways.
But for convenience we could add the normal On/Off Stems buttons as SHIFT+PAD 5 to SHIFT+PAD 8
FYI
The padpage on the extensions page.. each time one restarts VDJ.. it shows as needing an update.
Just reporting.
Yes I understand that now, after playing some more. It just seemed strange as I'm used to the on/off action.
another way would be to mimic the REV5 and have e.g. Pad 2 to be a SELECT PRM button (temporary or toggle) and then have the PADS 5 to 8 to work as normal Stem buttons when the SELECT is not enabled/pushed and ABPMT Stem params when enabled.
I was just playing with it.
I made this as an alt button 1, one button gets both decks going, include a loop 0 part to give it a larger scope
( action_deck 1 ? deck 2 play : deck 1 play ) & auto_bpm_transition & ( action_deck 1 ? deck 2 sync : deck 1 sync ) & repeat_start rsABT 25ms -1 & auto_bpm_transition ? : loop 0 & repeat_stop rsABT
Has this been removed from extensions?
No, but i just updated to add a couple more features brought in Early Access. Please try again
It's back :)
Thanks
So the Page is updated and ads the following..
Pad 2: AUTO-START option. If enabled, the Auto-BPM-Transition ON button , will also start the other Deck.
Param 2 : Source vs Target Option
- When set to Target (default), the Auto-BPM Transition will end up with the (original BPM if smartPlay and autoBpmMatch are enabled, or Current BPM if not) of the other Deck
- When set to Source, the Auto-BPM Transition will end up to the original BPM of the calling Deck.
PS. The additions require Build 7682 which is currently available as Early Access
the stems don't work for me.
Are you sure they generally work for you when used on other pad pages?
