Topic: Volume Control - Keyboard Shortcuts
Hi !! ... I'm a total newbie to VDJ.
1) How to use the keyboard shortcuts in VDJ? Whenever I type a key ... eg P, spacebar, etc. it goes into file search mode trying to locate the filename of that character.
2) Is there any keyboard shortcut to raise lower the volume of the active deck by say 1%? If not, can I map Ctrl-UpArr and Ctrl-DnArr to do the same, or is that already mapped to some other function.
3) How do I change focus from deck A to deck B .. and ... how do I know which deck the focus is currently on?
Thx.
geposted Sun 24 Sep 23 @ 8:58 am
Hello,
Example:
Increase level
Key: L
Action: level +1
Decrease level
Key: D
Action: level -1
Each time you press a button or key on the keyboard, the level increases or decreases.
Also in settings search for
searchBy
and select no
Thank You so much. That was really helpful. :)
