hello all...
The following problem.
The pads on my MC7000 flash in time with the music.
This effect is particularly strong when I have previously switched the LED around the jog wheel to 1 LED (Shift Deck 1).
Has anyone had this before, or does anyone have an explanation for it.
It is mainly on the left deck.
Firmware 1.2.
Firmware 1.2.
geposted Sun 24 Sep 23 @ 7:26 pm
Yes that is strange.
Troubleshooting:
1) is it the same when using the default mapping for the MC7000?
2) do the pads for all padpages flash... ie hotcues, saved loop, sampler, slicer, keycue and all the padpages you use?
or just some/one of them?
3) when the MC7000 boots, are all the pads and leds light as expected ?
could try vegas mode... holding vinyl when powering on .. to again check led functioning
(restart the MC7000 to exit vegas mode)
Troubleshooting:
geposted Sun 24 Sep 23 @ 8:37 pm
Troubleshooting:
Troubleshooting:
1.) yes but it is a little better
2) the pads and lighting of deck 3 are mainly affected.
It looks like the flashing is in sync with the LEDS around the jogwheel.
3.) During the boot ,everything works as expected
Can I disable the LEDS around the jogwheel as a test?
geposted Mon 25 Sep 23 @ 5:55 am
from 2) above..
You say more on deck 3.
I was asking if its different when pads are set to hotcues vs say saved loops or sampler?
(trying to rule out something with the pad page color scripting)
Do the pads on the skin, skin's deck 3 also flash.. the same way as those on the controller?
4) Does it only flash during the last 30 min of the track (the default) or the last number of seconds set by your setting, option: endOfSongWarning ?
the ring of Leds around the jogwheels are controlled by the controllers firmware. (with the shift-deck select) buttons for each deck
and secondarily controlled by the script of JOG_LEDMODE (again note the firmware will override any script here)
believe there are only two modes .. in the firmware
1) the one led ON,
2) all leds ON w one OFF.
so believe the leds cannot be disabled
Note: the led movement, replicates the movement of the skin's deck jog needle.
(which is affected by option: RPM and of course the speed of the tracks BPM/pitch)
a video w audio may also help
do all the pads flash at once.. or do they flash is some sequence.. etc
from 2) above..
1) the one led ON,
geposted Mon 25 Sep 23 @ 7:06 am
IIDEEJAYII wrote :
from 2) above..
1) the one led ON,
from 2) above..
1) the one led ON,
All pads are flashing.
For the Pad section it does not matter if it is cue hot cue or loop.
In the skin, there is no flashing visible.
In the meantime i found out, that when I deactivate ( change mapping )the led around the jogwheel, the flashing is gone…
It looks like that there is a problem with the Jog LEDs …
geposted Mon 25 Sep 23 @ 5:31 pm
Great you have more info as to what is causing the strange issue.
Curious how you are deactivating the leds around the jogwheel, or what you mean by that.
What change are you making to the mapping?
since one can change the led pattern with 4, shift-deck select buttons, alone.
and just changing the pattern this way, does that change the flashing of deck 3 pads?
Again the "deck 3 pad flashing", occurs when you are using the default MC7000 mapping, right?
geposted Mon 25 Sep 23 @ 6:15 pm
