Hi, I would like to DJ in a bar using a streaming service, but I can't find a legal way to find it. Anyone can help me?
Thanks
Gianfranco
Thanks
Gianfranco
geposted Wed 27 Sep 23 @ 3:59 pm
If you plan to use VDJ, then don't forget the first step of upgrading to a Pro license.
Either a monthly subscription if it's a short term gig. or the Pro Infinity (better if more then 15 months)
geposted Wed 27 Sep 23 @ 5:04 pm
That's for sure, but first I need to understand the matter with the tracks. Otherwise I won't do anything
geposted Thu 28 Sep 23 @ 9:44 am
That will differ by country
But the fist thing to check is the EULA for each streaming service
Most are for private use only - which you personally agree to when you sign up to them
geposted Thu 28 Sep 23 @ 12:35 pm
